OnPopup Event
Fires when a popup is about to be displayed.
SiteKiosk.SiteKioskUI.PopupManager.OnPopup = handler
webBrowser |
SiteKioskWebBrowser object that contains the browser. |
flags |
Long value that contains the flags (NWMF Enumerated Type). |
URLContext |
String that specifies the URL of the page that opens the popup. |
URL |
String that specifies the URL of the popup page. |
allowed |
Boolean value that indicates whether the popup is allowed. |
The following example displays whether a popup is allowed.
SiteKiosk.SiteKioskUI.PopupManager.OnPopup = OnPopup;
function OnPopup(webBrowser, flags, URLContext, URL, allowed)
alert(allowed);
