OnPopupBlocked Event
Fires when a popup has been blocked.
SiteKiosk.SiteKioskUI.PopupManager.OnPopupBlocked = handler
webBrowser |
SiteKioskWebBrowser object that contains the browser. |
flags |
Long value that contains the flags (NWMF Enumerated Type). |
URLContext |
String that specifies the URL of the page that opens the popup. |
URL |
String that specifies the URL of the popup page. |
The following example displays the URL of each blocked popup.
SiteKiosk.SiteKioskUI.PopupManager.OnPopupBlocked = OnPopupBlocked;
function OnPopupBlocked(webBrowser, flags, URLContext, URL)
alert(URL);
