ActiveFrame Property
The ActiveFrame property indicates whether to print the active frame.
PrintDialogOptions.ActiveFrame [=bool]
Boolean value that specifies or retrieves the status.
The following example prints the active frame of the document that the user requested to print.
options.ActiveFrame = true;
return false;
