PrintDialogOptions Object
The PrintDialogOptions object contains the print dialog options.
The following table lists the members provided by the PrintDialogOptions object.
This object is available through the Printer.OnShowPrintDialog event.
Use the PrintDialogOptions object to access the print dialog options.
The following example prints 2 copies of the document that the user requested to print.
options.Copies = 2;
return false;
