AreRatingsEnabled Property
The AreRatingsEnabled property indicates whether ratings are enabled.
[bool=] PrintDialogOptions.AreRatingsEnabled
The following example displays whether ratings are enabled when the user requests to print.
alert(options.AreRatingsEnabled);
return false;
