Copies Property
The Copies property contains the number of copies to print.
    PrintDialogOptions.Copies [=long]
    Long value that specifies or retrieves the number of copies.
    The following example prints 2 copies of the document that the user requested to print.
       options.Copies = 2;
       return false;
