Orientation Property
The Orientation property contains the type of orientation.
PrintDialogOptions.Orientation [=long]
Long value that specifies or retrieves the orientation.
Possible orientation types are:
DMORIENT_PORTRAIT = 1
DMORIENT_LANDSCAPE = 2
The following example prints the document that the user requested to print in portrait orientation.
options.Orientation = 1;
return false;
