PrinterName Property
The PrinterName property contains the name of the printer to be used.
    PrintDialogOptions.PrinterName [=str]
    String that specifies or retrieves the printer name.
    The following example prints the document that the user requested to print using the first available printer.
       fPrName = SiteKiosk.Printer.Printers.Item(1).PrinterName;
       options.PrinterName = fPrName;
       return false;
