RootDocumentHasFrameset Property
The RootDocumentHasFrameset property indicates whether the root document has a frameset.
    [bool=] PrintDialogOptions.RootDocumentHasFrameset
    The following example displays whether the root document has a frameset when the user requests to print.
       alert(options.RootDocumentHasFrameset);
       return false;
