ShortcutTable Property
The ShortcutTable property indicates whether to print a list of shortcuts at the end of the document.
PrintDialogOptions.ShortcutTable [=bool]
Boolean value that specifies or retrieves the status.
The following example prints the document that the user requested to print including a list of shortcuts at the end of the document.
options.ShortcutTable = true;
return false;
