OnShowPrintDialog Event
Fires when the SiteKiosk print dialog is displayed.
    SiteKiosk.Printer.OnShowPrintDialog = handler
Parameters Return Value
    Must return a Boolean value that specifies whether to cancel the print request.
    Whether the largest frame is printed automatically, the standard Internet Explorer print dialog is displayed, or the SiteKiosk print dialog is displayed has been configured in the SiteKiosk Wizard.
    The following example prints 2 copies of the document that the user requested to print.
       options.Copies = 2;
       return false;
