BlockMode Property
The BlockMode property indicates if the progress bar consists of several blocks.
    [bool=] SiteKiosk.Plugins("SiteCash").ProgressBarSettings.BlockMode
    Boolean value that retrieves the blockmode status.
    The following example shows the blockmode status in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").ProgressBarSettings.BlockMode);
