ProgressBarSettings Object
The ProgressBarSettings object controls the progress bar that displays remaining credit.
    The following table lists the members provided by the ProgressBarSettings object.
    Members
    Properties Description
    BlockMode If the bar consists of blocks.
    Color1 Bar color to start with.
    Color2 Bar color to fade in.
    Gradient If the bar color is gradient.
    Visible If the progress bar is visible.
    This object is available through the object SiteCash. Use the ProgressBarSettings object to change the appearance of the progress bar.
    The following example determines if the progress bar is visible and shows it in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").ProgressBarSettings.Visible);
