Gradient Property
The Gradient property indicates if the first progress bar color fades into another.
[bool=] SiteKiosk.Plugins("SiteCash").ProgressBarSettings.Gradient
Boolean value that retrieves the gradient status.
The following example shows the gradient status in an alert window.
alert(SiteKiosk.Plugins("SiteCash").ProgressBarSettings.Gradient);
