Visible Property
The Visible property indicates if the progress bar is to be visible.
[bool=] SiteKiosk.Plugins("SiteCash").ProgressBarSettings.Visible
Boolean value that retrieves the visibility.
The following example shows the visibility in an alert window.
alert(SiteKiosk.Plugins("SiteCash").ProgressBarSettings.Visible);
