Condition Property
The Condition property indicates when the receipt should be printed.
[long=] SiteKiosk.Plugins("SiteCash").ReceiptSettings.Condition
Long value that when the receipt should be printed.
The Condition Property returns the following options:
ONINPAYMENT = 1;
ONSESSIONEND = 2;
The following example binds the OfferReceipt function to the correct event depending on the Condition properties state.
SiteCash = SiteKiosk.Plugins("SiteCash");
ONINPAYMENT = 1;
ONSESSIONEND = 2;
switch (SiteCash.ReceiptSettings.Condition)
case ONINPAYMENT:
SiteCash.OnInpayment = OfferReceipt;
break;
case ONSESSIONEND:
SiteCash.OnSessionEnd = OfferReceipt;
break;
function OfferReceipt()
if (confirm("Do you want to get a receipt?"))
//do printing and/or mailing here...
