ReceiptSettings Object
The ReceiptSettings Object provides configuration values for payment receipts.
The following table lists the members provided by the ReceiptSettings object.
Properties |
Description |
Condition |
When the receipt should be send. |
IsEnabled |
Whether receipts are enabled. |
PrinterName |
Receives the receipt printers name. |
TemplateText |
Receives the template text with variables. |
Type |
Gets the receipt type. |
The following example illustrates how to handle simple receipt printing and mailing.
SiteCash = SiteKiosk.Plugins("SiteCash");
ONINPAYMENT = 1;
ONSESSIONEND = 2;
PRINT = 1;
SEND_EMAIL = 2;
if (SiteCash.ReceiptSettings.IsEnabled)
switch (SiteCash.ReceiptSettings.Condition)
case ONINPAYMENT:
SiteCash.OnInpayment = OfferReceipt;
break;
case ONSESSIONEND:
SiteCash.OnSessionEnd = OfferReceipt;
break;
function OfferReceipt()
var text = SiteCash.Macromap.Expand(
SiteCash.ReceiptSettings.TemplateText);
switch (SiteCash.ReceiptSettings.Type)
case PRINT:
if (confirm("Do you want to print a receipt?"))
var printer = SiteKiosk.Printer.FindPrinter(
SiteCash.ReceiptSettings.PrinterName);
if (printer)
printer.PrintDocument("Arial", 80, text,
"", "", false);
break;
case SEND_EMAIL:
if (confirm("Do you want to send a email receipt?"))
var email = SiteKiosk.Email.CreateJob(true);
email.PlainBody = text;
email.AddRecipient("someone@examle.com");
email.Send();
break;
