IsEnabled Property
The IsEnabled property indicates whether receipts are enabled.
    [bool=] SiteKiosk.Plugins("SiteCash").ReceiptSettings.IsEnabled
    Boolean value that retrieves whether receipts are enabled.
    The following example shows whether receipts are enabled.
    alert(SiteKiosk.Plugins("SiteCash").ReceiptSettings.IsEnabled);
