Type Property
The Type property indicates how receipts should be delivered.
    [long=] SiteKiosk.Plugins("SiteCash").ReceiptSettings.Type
    Long value that retrieves how receipts should be delivered.
    The Type Property can return the following states:
    PRINT = 1;
    SEND_EMAIL = 2;
    The following example shows how to support different receipt deliveries.
    SiteCash = SiteKiosk.Plugins("SiteCash");
    PRINT = 1;
    SEND_EMAIL = 2;
    SiteCash.OnSessionEnd = OfferReceipt;
    function OfferReceipt()
        switch (SiteCash.ReceiptSettings.Type)
            case PRINT:
                if (confirm("Do you want to print a receipt?"))
                    //Do printing here...
                break;
            case SEND_EMAIL:
                if (confirm("Do you want to send a email receipt?"))
                    //Do mailing here...
                break;
