Item Method
The Item method returns one item of the collection.
    [obj=] SiteKiosk.CDRecording.RecorderList.Item(index)
    index Long value that contains the item number to return.
    Returns a CDRecorder object that provides information about the CD recorder.
    Collection-index values are 1-based.
    The following example shows the maximum write speed of an available CD recorder in an alert window.
    if (SiteKiosk.CDRecording.RecorderList.Count > 0)
       alert(SiteKiosk.CDRecording.RecorderList.Item(1).MaxWriteSpeed);
    else
       alert("Could not find a CD recorder");
