Import Method
The Import method imports a file or directory.
    SiteKiosk.CDRecording.RootDirectory.Import(name)
    name String that specifies the name of the file or directory.
    The following example imports a complete directory.
    SiteKiosk.CDRecording.RootDirectory.Import("c:/dir");
