Rename Method
The Rename method renames a subdirectory of the root directory.
SiteKiosk.CDRecording.RootDirectory.Rename(oldname, newname)
oldname |
String that specifies the old name of the subdirectory. |
newname |
String that specifies the new name of the subdirectory. |
The following example creates and renames a subdirectory of the root directory.
newDir = SiteKiosk.CDRecording.RootDirectory.CreateDirectory("dir");
SiteKiosk.CDRecording.RootDirectory.Rename("dir", "newdir");
