IsCreditAccount Property
The IsCreditAccount property indicates whether the credit function has been enabled in the configuration.
[bool=] SiteKiosk.Plugins("SiteCash").RuntimeMenuSettings.
IsCreditAccount
The following example determines whether the credit function is enabled and shows it in an alert window.
var RMSettings = SiteKiosk.Plugins("SiteCash").RuntimeMenuSettings;
alert(RMSettings.IsCreditAccount);
