RuntimeMenuSettings Object
The RuntimeMenuSettings object contains the settings of the runtime administration menu.
The following table lists the members provided by the RuntimeMenuSettings object.
This object is available through the object SiteCash.
Use the RuntimeMenuSettings object to receive the administration menu settings.
The following example determines whether a shutdown button should be displayed ind the administration menu and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteCash").RuntimeMenuSettings.IsShutdown);
