IsSalesReport Property
The IsSalesReport property indicates whether the sales report function has been enabled in the configuration.
    [bool=] SiteKiosk.Plugins("SiteCash").RuntimeMenuSettings.IsSalesReport
    The following example determines whether the sales report function is enabled and shows it in an alert window.
    var RMSettings = SiteKiosk.Plugins("SiteCash").RuntimeMenuSettings;
    alert(RMSettings.IsSalesReport);
