IsShowLastLogFile Property
The IsShowLastLogFile property indicates whether the logfile function has been enabled in the configuration.
[bool=] SiteKiosk.Plugins("SiteCash").RuntimeMenuSettings.
IsShowLastLogFile
The following example determines whether the logfile function is enabled and shows it in an alert window.
var RMSettings = SiteKiosk.Plugins("SiteCash").RuntimeMenuSettings;
alert(RMSettings.IsShowLastLogFile);
