IsShutdown Property
The IsShutdown property indicates whether the shutdown function has been enabled in the configuration.
[bool=] SiteKiosk.Plugins("SiteCash").RuntimeMenuSettings.IsShutdown
The following example determines whether the shutdown function is enabled and shows it in an alert window.
var RMSettings = SiteKiosk.Plugins("SiteCash").RuntimeMenuSettings;
alert(RMSettings.IsShutdown);
