AddDelayedEvent Method
The AddDelayedEvent method calls a script function after a specified delay.
[evtid=] SiteKiosk.Scheduler.AddDelayedEvent(delay, func)
delay |
Long value that specifies the delay. |
func |
Function that is called after the specified delay. |
Returns a Long value that contains the event ID.
The func parameter can be a JavaScript or VBScript function. When this function is called, the event ID is transmitted as a parameter.
The following example calls a JavaScript function after 5 seconds.
evtid = SiteKiosk.Scheduler.AddDelayedEvent(5000, myfunction);
function myfunction(eventID)
alert("5 seconds have passed");
