Scheduler Object
The Scheduler object provides creating timed events.
    This object is available through the main object SiteKiosk. Use the Scheduler object to start events at a specified time.
    The following example shows the scheduler functionality.
    function sstartaction()
       if (saction[0].checked) SiteKiosk.Quit();
       if (saction[1].checked) SiteKiosk.ShutdownWindows();
       if (saction[2].checked) SiteKiosk.RebootWindows();
       if (saction[3].checked) SiteKiosk.LogoffWindows();
    function startscheduler()
       myevtid = SiteKiosk.Scheduler.AddDelayedEvent(stime.value*1000,
       sstartaction);
       id_sas.innerHTML = "Status: Scheduler started";
    align="center">
    <tr><td bgcolor="f8f8f8">
    When the link is clicked, the specified action will be
    started when the specified time elapsed. The scheduler
    can be used for various actions.
    </td></tr>
    <pre>
    <input type="radio" name="saction"> Quit SiteKiosk
    <input type="radio" name="saction" checked> Shutdown Windows
    <input type="radio" name="saction"> Reboot Windows
    <input type="radio" name="saction"> Logout Windows user
    <br>
    &nbsp;Time in seconds
    &nbsp;<select name="stime" size="1" style="width:150px;">
    <option value="5">5</option>
    <option value="10">10</option>
    <option value="15">15</option>
    </select>
    <br>
    <br>
    <span style="color:#cc3300;" id="id_sas">Status: inactive</span>
    </pre>
    </td></tr>
    </table>
    <div align="center">
    <a href="javascript:startscheduler()">
    Activate
    </a>
    The following example can be modified and added to the "TrayWindow.html" of the used browser skin to achieve that SiteKiosk reboots or shuts down at an exact point of time.
    <script language="javascript">
    // Time:
    // use time in 24-hour format (HH:MM)
    // and "0" for no action.
    // Example:
    // sWeekDays[1] = "01:25"; // Time Mondays 1:25 a.m.
    // Action:
    // true=reboot, false=shutdown
    // Example:
    // bWeekReboot[1] = false;  // Shutdown Mondays
    var sWeekDays = new Array();
    var bWeekReboot = new Array();
    // Monday:
    sWeekDays[1] = "0";
    bWeekReboot[1] = true;
    // Tuesday
    sWeekDays[2] = "0";
    bWeekReboot[2] = true;
    // Wednesday
    sWeekDays[3] = "0";
    bWeekReboot[3] = true;
    // Thursday
    sWeekDays[4] = "0";
    bWeekReboot[4] = true;
    // Friday
    sWeekDays[5] = "0";
    bWeekReboot[5] = true;
    // Saturday
    sWeekDays[6] = "0";
    bWeekReboot[6] = true;
    // Sunday
    sWeekDays[7] = "0";
    bWeekReboot[7] = true;
    // Cutomizable Scheduler to reboot/shutdown this terminal
    function CreateShutdownScheduler()
       var CurrentDate = new Date();
       var Day = CurrentDate.getDay();
       var strDays = new String();
       if (sWeekDays[Day] != "0")
          strDays = sWeekDays[Day];
          if (bWeekReboot[Day])
             SiteKiosk.Scheduler.AddFixedTimeEvent(
             parseInt(strDays.substring(0, 2)),
             parseInt(strDays.substring(3, 5)), 0,
             RebootScheduler);
          }else
             ShutdownScheduler);
    // Customizable function to reboot
    function RebootScheduler(eventID)
    // Customizable function to shutdown
    function ShutdownScheduler(eventID)
    // Create Scheduler to shutdown/reboot the terminal
    CreateShutdownScheduler();
    </script>
