Active Property
The Active property indicates if the screensaver is currently active.
    [bool=] SiteKiosk.ScreenSaver.Active
    Boolean value that retrieves the activity status.
    The following example determines if the screensaver is currently active and shows it in an alert window.
    alert(SiteKiosk.ScreenSaver.Active);
