ScreenSaver Object
The ScreenSaver object controls the screensaver.
    The following table lists the members provided by the ScreenSaver object.
    Members
    Properties Description
    Active If the screensaver is active.
    Enabled If the screensaver is enabled.
    IdleTime Contains the idle time.
    RunningTime Current running time.
    WaitTime Contains the wait time.
    Methods Description
    Activate Starts the screensaver.
    Reactivate Reactivates SiteKiosk.
    Events Description
    OnScreenSaverActivator Fires when a sensor detects activity/inactivity.
    OnScreenSaverBegin Fires when the screensaver becomes active.
    OnScreenSaverEnd Fires when the screensaver becomes inactive.
    This object is available through the main object SiteKiosk. Use the ScreenSaver object to receive the screensaver settings or to reactivate it.
    The following example shows in an alert window if the screensaver is active.
    alert(SiteKiosk.ScreenSaver.Active);
