Enabled Property
The Enabled property indicates if the SiteKiosk screensaver has been enabled in the configuration.
    [bool=] SiteKiosk.ScreenSaver.Enabled
    The following example determines if the screensaver has been enabled in the configuration and shows it in an alert window.
    alert(SiteKiosk.ScreenSaver.Enabled);
