RunningTime Property
The RunningTime property contains the duration of the currently active screensaver.
    [long=] SiteKiosk.ScreenSaver.RunningTime
    Long value that retrieves the last running time.
    This property is reset each time SiteKiosk is reactivated. None.
    The following example shows the last running time in an alert window.
    alert(SiteKiosk.ScreenSaver.RunningTime);
