WaitTime Property
The WaitTime property contains the period of idle time after which the screensaver will be activated.
    [long=] SiteKiosk.ScreenSaver.WaitTime
    Long value that retrieves the number of seconds.
    The wait time can be defined in the SiteKiosk configuration.
    The following example shows the seconds to wait in an alert window.
    alert(SiteKiosk.ScreenSaver.WaitTime);
