Credit Method
The Credit method increases the amount of available credit.
SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice").Credit(cur, bool)
cur |
Currency value that specifies the amount to add. |
bool |
Boolean value that specifies if the amount should be booked directly into the main account of the SiteCash object. |
The following example increases the credit of the script device account.
SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice").Credit(5, false);
