OnCheckRetransfer Event
Fires when SiteKiosk checks if the payment device can return credit to the script device account.
SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice").
OnCheckRetransfer = handler
amount |
Currency value that contains the amount which can be returned. |
The defined function of this event can tell SiteKiosk that returning credit is possible using the return command. If this function returns false or nothing, the RetransferEnabled property defines the possibility of returning credit.
Use the CurrencyFormatter object for currency functionality.
The following example shows an alert window when SiteKiosk checks if credit can be returned and returns that this is possible.
sdevice = SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice");
sdevice.OnCheckRetransfer = OnCheckRetransfer;
function OnCheckRetransfer(amount)
alert(amount);
return true;
