OnRetransfer Event
Fires when the payment device returns credit to the script device account.
    SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice").
    OnRetransfer = handler
    amount Currency value that contains the amount which is returned.
    If the defined function of this event returns true, existing credit will not be added to the script device account. If false is returned and the RetransferEnabled property is true, existing credit from the account of the SiteCash object will be added to the script device account.
    Use the CurrencyFormatter object for currency functionality.
    The following example shows an alert window when the payment device wants to return credit and allows this.
    sdevice = SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice");
    sdevice.OnRetransfer = OnRetransfer;
    function OnRetransfer(amount)
       alert(amount);
       return false;
