Enabled Property
The Enabled property indicates if the Webcam plugin is enabled.
[bool=] SiteKiosk.Plugins("SiteCam").Enabled
Boolean value that indicates if the Webcam plugin is active.
The following example determines if the Webcam plugin is enabled and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteCam").Enabled);
