SiteCam Object
The SiteCam object provides information about the Webcam plugin.
    The following table lists the members provided by the SiteCam object.
    Members
    Properties Description
    Enabled If the Webcam plugin is enabled.
    Name Name of this plugin.
    This object is available through the collection Plugins. Use the SiteCam object to determine if this plugin is enabled.
    The following example determines if the Webcam plugin is enabled and shows it in an alert window.
    alert(SiteKiosk.Plugins("SiteCam").Enabled);
