GetCoinImageFilename Method
The GetCoinImageFilename method determines the filename of the specified coin or note image.
    [str=] SiteKiosk.Plugins("SiteCash").GetCoinImageFilename(iso, val, note)
    iso String that contains the ISO code.
    val Currency value that contains the coin or note value.
    note Boolean value that specifies whether the value is a note.
    Returns a String that contains the filename of the coin or note image.
    Use the CurrencyFormatter object for currency functionality.
    The coin and note images filenames are saved in the configuraton.
    The following example shows the filename of a coin image in an alert window.
    scash = SiteKiosk.Plugins("SiteCash");
    imgfile = scash.GetCoinImageFilename("50 Cent", 0.50, false);
    alert(imgfile);
