OnEscrowed Event
Fires when an escrow device keeps money.
SiteKiosk.Plugins("SiteCash").OnEscrowed = handler
obj |
DevInfoAdapter object that represents the device. |
amount |
Currency value that contains the amount. |
Use the CurrencyFormatter object for currency functionality.
The following example shows the amount when an escrow device keeps money.
SiteKiosk.Plugins("SiteCash").OnEscrowed = OnEscrowed;
function OnEscrowed(obj, amount)
alert(amount);
