ClearCacheOnStartup Property
The ClearCacheOnStartup property indicates if the cache is to be cleared on startup.
    [bool=] SiteKiosk.Plugins("SiteCoach").ClearCacheOnStartup
    Boolean value that retrieves if the cache is to be cleared.
    The following example determines if the cache is to be cleared on startup and shows it in an alert window.
    alert(SiteKiosk.Plugins("SiteCoach").ClearCacheOnStartup);
