SiteCoach Object
The SiteCoach object controls the environment of the Content Filter plugin.
    The following table lists the members provided by the SiteCoach object.
    Members
    Properties Description
    ClearCacheOnStartup If the cache should be cleared on startup.
    Enabled If the Content Filter is enabled.
    FilterState If the Content Filter filter is active.
    Name Name of this plugin.
    Events Description
    OnBlockURL Fires when an URL is blocked.
    OnFilterStateChanged Fires when the filter status changed.
    This object is available through the collection Plugins. Use the SiteCoach object to enable or disable blocking web pages or to get settings of this plugin.
    The following example shows information about the Content Filter plugin.
    align="center">
    <tr><td bgcolor="f8f8f8">
    Try to open the forbidden URL when the Content Filter [Plug-In]
    filter is activated.
    </td></tr>
    <pre>
    if (SiteKiosk.Plugins('SiteCoach').Enabled)
       coachstatus = "Content Filter Plugin is active";
       if (SiteKiosk.Plugins("SiteCoach").FilterState)
       coachfilterstatus = "activated";
       else coachfilterstatus = "deactivated";
    else
       coachstatus = "Content Filter Plugin has not been configured";
       coachfilterstatus = "-";
    document.writeln("Status: " + coachstatus);
    document.write("<span id='id_scoachfilter'>Filter: " +
    coachfilterstatus + "</span>");
    function adswitch()
          SiteKiosk.Plugins("SiteCoach").FilterState =
          !SiteKiosk.Plugins("SiteCoach").FilterState;
       } else alert("Content Filter Plugin has not been configured");
    function openurl()
       window.open("http://www.sex.com");
    SiteKiosk.Plugins("SiteCoach").OnFilterStateChanged = OFSChanged;
    function OFSChanged()
       id_scoachfilter.innerHTML = "Filter: " + coachfilterstatus;
    </pre>
    </td></tr>
    </table>
    <div align="center">
    <a href="javascript:adswitch()">Activate / Deactivate</a>
    &nbsp;
    <a href="javascript:openurl()">Open URL</a>
