Enabled Property
The Enabled property indicates if the Content Filter plugin is enabled.
[bool=] SiteKiosk.Plugins("SiteCoach").Enabled
Boolean value that indicates if the Content Filter is active.
The following example determines if the Content Filter plugin is enabled and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteCoach").Enabled);
