FilterState Property
The FilterState property indicates if the Content Filter plugin is active.
    SiteKiosk.Plugins("SiteCoach").FilterState [=bool]
    Boolean value that specifies or retrieves if the
    filter is active.
    The following example determines if the filter is active and shows it in an alert window.
    alert(SiteKiosk.Plugins("SiteCoach").FilterState);
