Name Property
The Name property contains the name of this plugin.
    [str=] SiteKiosk.Plugins("SiteCoach").Name
    The internal name of the Content Filter plugin is "SiteCoach".
    The following example shows the name of this plugin in an alert window.
    alert(SiteKiosk.Plugins.Item(3).Name);
