Enabled Property
The Enabled property indicates if the Hardware Watchdog plugin is enabled.
    [bool=] SiteKiosk.Plugins("SiteDog").Enabled
    Boolean value that indicates if the Hardware Watchdog is active.
    The following example determines if the Hardware Watchdog is enabled and shows it in an alert window.
    alert(SiteKiosk.Plugins("SiteDog").Enabled);
