SiteDog Object
The SiteDog object provides information about the Hardware Watchdog plugin.
    The following table lists the members provided by the SiteDog object.
    Members
    Properties Description
    Enabled If the Hardware Watchdog is enabled.
    Name Name of this plugin.
    This object is available through the collection Plugins. Use the SiteDog object to determine if this plugin is enabled.
    The following example determines if the Hardware Watchdog is enabled and shows it in an alert window.
    alert(SiteKiosk.Plugins("SiteDog").Enabled);
