Name Property
The Name property contains the name of this plugin.
[str=] SiteKiosk.Plugins("SiteDog").Name
The internal name of the Hardware Watchdog plugin is "SiteDog".
The following example shows the name of this plugin in an alert window.
alert(SiteKiosk.Plugins.Item(4).Name);
