OnQuit2 Event
Fires while SiteKiosk is terminated.
SiteKiosk.OnQuit2 = handler
shutdownmode |
Integer value that contains the shutdown mode. |
The shutdown mode can be one of the following:
0 : Quit
1 : Restart
2 : Reboot
3 : Shutdown
4 : Logoff
This event fires directly after OnQuit.
The following example shows the shutdown mode in an alert window when SiteKiosk is terminated.
SiteKiosk.OnQuit2 = OnQuit2;
function OnQuit2(shutdownmode)
alert(shutdownmode);
